Online: Soapbox2627, HD17, Hilly
vance@hines slip on for 2012 fatboy
  • woodybill
    woodybill
    in the process of fitting v@h slip ons and to line top pipe up i would have to cut about 25 mm off the clamp end off  muffler.has anyone had this problem.checking befor i cut or take back
  • Retroman
    Slip on mufflers change dramatically between the up to 2006 and 2007 and up bikes.
    Same time as the change from 88 Cube to 96 cube
    Be careful you have the corect model/year slip on mufflers !!
    Too hard basket if you don't !!
    You shouldn't need to cut anything if for the right bike and model
  • woodybill
    woodybill
    good on ya men.ill take them back to the harley shop tomorrow
