Redshift 527 Cams
  • Will67
    Will67
     have been told that the s&s easy start  option are a better way to go just what i  been told and im using... great invention less strain on batteries,starters, depends on your budget to i guess........ potatoe potatoe
    www.sscycle.com/feature/featureview.php
  • HogBag
    HogBag
    Hilly
    Check out the 24d or 2c-2d for a stock 96.
    http://www.kuryakyn.com/products/1601/cams-for-twin-cam
