Online: GGUser744
FLOORBOARDS FITTED ON FATBOB
  • shingles
    shingles
    since my long ride 340ks  which really told me i av 2 make changes 2 make ride easier on my bad leg ,i want 2 do longer rides like wen i was ok so saw some floorboards at J&P cycles usa i buy from that site a lot ,the boards were different than most and solid metal  . board  itself strate one side curve at heel then 3inch along angles bak down 2 say 2inch then curve again an man these r heavy duty metal 1/2 inch thik easy all solid chrome both sides polished with rubber deck in shapes  slitely raised 4 cushioning an fit mount no bits needed ,tryed on bike nah not wide enough argh so look at bits an pieces fittings an stuff found wat i think will fix kuryakin 2 inch by  360  degrese pivot part mounted strate onto footpeg mount first bit then bolted 2 inch piece to that which can full rotate 360 then last piece to that also 360 rotateable now ive got wat i was tryin 2 achieve useing 2inch adjustable lockable offset kuryakin product ,even if u want 2 bring your pegs back an up all is possible useing this part also forward and down has serated adjustment system ive got one board up an bak to suit bad leg an other board different so many varibles can be had and moves board or peg out further on brake side so if u have heavy breather your peg or bord couple inches  further out more relaxed not tryin 2 hold ya leg against breather u can av pegs up higher less chance scrapein ,with brake pedal harder 2 hit coz of breather i got big shifter some cardboard bent out more so can use easier mite even buy longer brake pedal ,all pieces cost about 260 2 door from usa ,floorboards i chose were on special 88buk parts cheap frieght like 43buk but ive been buyin from that site 4 a while gold membership makes cheaper costs 50 buk but if ya buy bits like i do is worth it ,and i did fitment myself which is a strain 4 me coz of leg but is done ,lots more 2 do on bike yet SHINGLES
  • Normthe1
    Normthe1
    Fuck Shingles, I always try to read your posts but have you not heard of a full stop? No offence mate, but they are fucking hard to read.
    I'm not having a go about the content, but just about how hard they are to read...
    Sorry dude...
    It's not a full stop, it's a paragraph here or there, just to break up the big block of text.
    And Shingles, whatever keeps you riding is a good thing. Good to see you found a fix.
  • shingles
    shingles
    yep i see now wat u mean it was late an i not smartest wen writen happenin my stories ,sorry about lack of proper writen skills wen typen i just keep pushin letters untill all i can think off is done ,was wif one eye on floor dr,s meds it takes me so long 2 write stories and i will try 2 make more legibal ,i can only try sometimes will be better an perhaps sometimes not jus depends if im in control or not quite cheers SHINGLES AND 1 day may be able 2 show photo,s havent worked that out as yet ,and that doe,s annoy me greatly not being able 2 show my bike coz im proud of my bike an would like others 2 see mods but alas no can do not smart enough yet.
  • shingles
    shingles
    somehow ive jagged how 2 put piks on site ,think i no wat i did ah ha now can get piks of my bike on site just need the photos ,daughter is only one here that nows how 2 put from phone to my facebook an somehow ive moved them an moved again jus gotta think wat i did this nothin about subject but i jus put piks of boards in my first quote on subject which im still adjusting they work ok just tweaking a bit on gearchange side well both sides really SHINGLES
  • Dutchy Hoogen
    Dutchy Hoogen
    Hey Shingles those boards look shit hot mate. Like to know how they go as far as scraping. I've got a Fatbob too and thought about the boards for mine. What's holding me back is that I scrape the pipes and the peg on the otherside now. Please let me know how she goes in the twists mate.
  • shingles
    shingles
    no probs in bends scraped a bit on right side but i have multi adjusters 2 inch offset gadjets if u look at piks u will see adjusters they rotate 360 at intervals in serated head ,i can change at peg mount and also at floorboard so i have 2 places 2 change angles ,those adjusters are for rear adjusting but just stuck em on front same thing different place ,never had any issusues with them also they tilt those boards and they are solid steel chromed ,ive taken off now as couldnt find total comfort with bad leg so have gone back 2 round peg made by avon its thick and has grippy soft raised rubber rings on solid steel chromed heavy duty have grips the same seems 2 allow my shoe on bad leg 2 b more comfortable its hard coz i dont have any movement in foot at all no ankle all fused an rodded so foot just relys on shoe to be in happy place also knee been ripped out no cartalige bone on bone have to turn leg at hip also cant feel foot i no its there just dont have certain things that once had ,floorboards for sale and you never see again as not made anymore good quality and not overly big and you can swap over either side so you can hav big end down or narrow end down to eliminate scraping or jus get same atachment bits an you can bring em up an back or forward an tilted hope this helps SHINGLES
  • shingles
    shingles
    YEP was tryin either way just anything 2 get right ,and after all the trying just couldnt get my leg in all its new bends and angles 2 feel right so fuk it bought new round avon pegs with raised rings rubber with grippy soft rubber seems 2 let my shoe sit and grip ok its all in the shoe being right as i cant control foot its all pinned and fused no ankle just a foot in a shoe and a fuked knee can only bend knee 6inches either way at best so am constantly tryin 2 find the right posi those adjusters help immensely lets me go forward up back down also rotate peg its never going to be right to much damage ,change gears with heel cant feel it but i know thats where gear lever is and all i have to do is push it and changes gear anyway thats y boards maybe upside down or watever jus tryin 2 find somethin that makes leg comfy its not working really but can still get about ,is an effort though not easy but can do just have 2 be on your game SHINGLES
  • Dutchy Hoogen
    Dutchy Hoogen
    Thanks Shingles. Might give the boards a go.
  • shingles
    shingles
    how ya's all going well decided to fire up motorbike amazing isn't it ,just been adjusting peg posi again and gear levers posi coz when change peg or boards lever not right anymore well were my foot thinks it was anyway just got back from brisk 150k ride sat on 120-to whatever wen able to open up full throttle then back off a bit mainly sat on 120-130 thought I'd try me luck an see if dem blu reds appear only saw them at place were is 60ks an all road shit just before bangalow up that stupid hill mustave been 6 plus HWY patrol mean looking cars more airials on them that a space shuttle jus pulled in clutch an idled past as quiet as could be they were outa cars an gave us a good look but I just in casual shirt 2 day no black leathers on an no pursuit was engaged just putted 2 bangalow an had beer at pub only 1 thinking will I go back past all dem jokers can go different way ,ah fuck it geared up an putted off back onto HWY stayin in left lane tryin 2 just be a nobody was strange 4 a few kays this car behind which appeared seemed to have strange headlight functions drivers side would go really bright like high beam but not then would go off then would do it again and go back to normal now that's not normal by any means this car had something going on with headlights then car would come quick then drop back ,im not giving this prick any reason coz somthin goin on and then came flying up an past me at a great rate of knots and plates were dat gov shit COA I goes hummm must be able 2 see number plate with watever that bright light shining out of drivers side headlights its not high beam coz we have cars coming other way an no one flashed and even from behind in my mirrors wasn't like car with high beam so theres one for ya theve checked me out an all was good then sped past me like smart arses then slowed a few kays up every cunt was usein them as frontrunner not nowin dat in dat car was feds in the end the cunts backed off an I caught up they didn't seem 2 like that then fuk cunt jus turned left nearly past exit and hammered it and I just went 2 myself you've just been made kunt so there ya go I got to blast away on way back hit ton plus few times sat on 130-140 wanted 2 get home and don't really care coz in mood 2 give it da be geezez and I did fuk it was kraklein in dark as well ,got bike in yard was glowin me ears still in roar mode and I even adjusted gear lever coz wasn't right now av beer sittin in skivvies fuked ,sorry bout ya mate baloff its not fun wen busted up and ya lifes just a constant pile of fukups ,once we get 2 broken thers no way back its gone your whole way of life ruined cant get that back when I go 2 sleep don't no im broken only wen awake ,fuk I sleep a lot SHINGLES how in da heck do ya space lines now its all differnt from before i aint no genius wen it comes 2 dis writing caper tryed 2 gap other day pushed sum button whole lot vanished an been writein 4 good hr got da shits an turned fukin thing off please tell me
  • Alan54
    Alan54
    Fuck Shingles,,340 km is not a long ride, I regularly rode from Sydney to Brisbane to hook up with mates & party on my then softail, no floorboards required,,just ride, get there & have fun. Always rode back in one day via the Putty Rd.
    Also your post is hard to read without some form of punctuation,,Alan
  • Alan54
    Alan54
  • fat103
    fat103
    I personly don't have a problem with how blokes type up their post's and as for Shingles I get enjoyment outa reading his as this forum is all about getting info out there to each other and not about slinging off about punctuation and so on !!!  Shingles tells it how it is !!yes
  • shingles
    shingles
    wel for all members my english or whatever yes it is just as hard for me 2 write as is 4 sum 2 understand my expression of things that i find the ability 2 push buttons that make words and i understand the complexity of sum writeings ,it seems all good 2 me as im puttin forth what comes tpo mind with one finger and do not cdhek as sutch a lot of tmes as is late an medicine is sendin me left rite west east as im sittoin now drool is runnin down my chin coz im in a place far from here but close as well . I jus did a fulll stop firstly i went 2 special school if sum readers may no of this or may not means i was dum ass no fault of mine wat do day call it generic aw dunno really ,an yes 350ks was a big ride 4 thee coz i aint made same as was due 2 unforseen circamstances ,an yep i used to do bathurst every yr untill dem plods stopped it i was there in dem roits well really it was all a bit of a game .Task force from melb wanted 2 test itself in a roit well where do ya get one of those ah ha go 2 the easter bike event stir up sum shit cave a few heads in make sure tv crews are there first i watched all this unfold ,as this task force twits came out of compound an grabbed anyone as was adjacent to food canteen an people were just heading back 2 there campsite ,nothing really bad goes on there even if patched every body sticks to there own place what really got things going waswen guy with girl standing on pegs goin past unclothed ,one of them coppers attacked her with trounchon nockin her off bike and then well that was the first step then theyed all go back in compound lock gate go inside everybody just went back to normal then after a while could be hours theyed come out out again running with full plastic shields an battons an belt da fuk outa any cunt an drag person back inside they were not realeased but taken away in big armoured truck uh hummm me saz ,shes not what shee seems there is trouble afoot and i was right early in next day when everyone sleeping they came an opened tents went in an arrested people at will they snuk a whole heap of coppers an paddy wagons up before dawn and it was like get da fuk outa here ,i was aware of this coming an me an brother hit starters an took off like a bat outta hell they blocked way down but us boys were dirt bags so up an over big mound and went down this dirt track and got back on tar an lit da wick dunno what made me write this story have no fukkin idea at all ,aw yeah could ride long way once was  that day,left about 6.30 7 am bathurst was fogged up dark but  was bak on gold coast havin a beer at 4pm burliegh shark bar  from bathurst mind u 1275ks now how do ya space lines coz got me fuked
  • shingles
    shingles
    wel for all members my english or whatever yes it is just as hard for me 2 write as is 4 sum 2 understand my expression of things that i find the ability 2 push buttons that make words and i understand the complexity of sum writeings ,it seems all good 2 me as im puttin forth what comes tpo mind with one finger and do not cdhek as sutch a lot of tmes as is late an medicine is sendin me left rite west east as im sittoin now drool is runnin down my chin coz im in a place far from here but close as well . I jus did a fulll stop firstly i went 2 special school if sum readers may no of this or may not means i was dum ass no fault of mine wat do day call it generic aw dunno really ,an yes 350ks was a big ride 4 thee coz i aint made same as was due 2 unforseen circamstances ,an yep i used to do bathurst every yr untill dem plods stopped it i was there in dem roits well really it was all a bit of a game .Task force from melb wanted 2 test itself in a roit well where do ya get one of those ah ha go 2 the easter bike event stir up sum shit cave a few heads in make sure tv crews are there first i watched all this unfold ,as this task force twits came out of compound an grabbed anyone as was adjacent to food canteen an people were just heading back 2 there campsite ,nothing really bad goes on there even if patched every body sticks to there own place what really got things going waswen guy with girl standing on pegs goin past unclothed ,one of them coppers attacked her with trounchon nockin her off bike and then well that was the first step then theyed all go back in compound lock gate go inside everybody just went back to normal then after a while could be hours theyed come out out again running with full plastic shields an battons an belt da fuk outa any cunt an drag person back inside they were not realeased but taken away in big armoured truck uh hummm me saz ,shes not what shee seems there is trouble afoot and i was right early in next day when everyone sleeping they came an opened tents went in an arrested people at will they snuk a whole heap of coppers an paddy wagons up before dawn and it was like get da fuk outa here ,i was aware of this coming an me an brother hit starters an took off like a bat outta hell they blocked way down but us boys were dirt bags so up an over big mound and went down this dirt track and got back on tar an lit da wick dunno what made me write this story have no fukkin idea at all ,aw yeah could ride long way once was  that day,left about 6.30 7 am bathurst was fogged up dark but  was bak on gold coast havin a beer at 4pm burliegh shark bar  from bathurst mind u 1275ks now how do ya space lines coz got me fuked o no twice again dats it im done
  • shingles
    shingles
    nothin 2 do wif floorboards but being very new 2 computa's an geez sometimes da stress of doin writin more painfull than accident i had on my bike ,so many words 2 say crash but wats dis shit dat keeps coming on screen  PC PERFORMANCE SLOW PUSH BUTTON NOW  wat an all will be fixed does that do my leg 2 ,fuk just had somebody buy lounge in states on my card 1800 buks dont even hav passport oh im dum ,have harley makes big noise must be bad fella betta pull im over o fuk he;s makin a run 4 it quik giv im a volley of u no burrrrt out window must be on da run ,well no actually i was scared of intimidation if stopped an wrist locked bashed even liberty gone fuk it i'd rather run take my chance's ive a phobia about blue checkered  blue as we'll tell u wen an wat is ,an wat ain't fella been through it lie's after lie's ,o an u say but if ya done nothin it be ok well sometimes just does'nt work like book say's .,bloody rain again SHINGLES
  • shingles
    shingles
    CRIPES somehow gettin 2 entries up pushed sumthin wrong imagine sendin me 2 shops ,yes mum ive got it but instead cum home wif wrong shit again and worst of all im sitting in wrong house ha ha ha ha ha has happened SHINGLED
