Rear Fork Bearings and Pulley
  • 6gear
    6gear
     Just wondering if anyone has seen bearings like this after 41,000 miles on a Fat Boy?
    Also, any comments about the need to replace the pulley? The belt is in great shape.
    Thanks
  • Colstah
    Colstah
    Wow, that's ugly!!
    For the cost of a sprocket, I'd be replacing it. It's a wonder the belt isn't chewed up....they must be tough little buggers!
  • 6gear
    6gear
    This is trail damage after 41,000 miles across Vietnam. I was always concerned about my front end, and that checked out with no problem. The rear fork bearings were a surprise.
    This is the second pulley. I replaced previously when it looked almost this bad. A guy here in the US showed me a pulley off a big inch motor with teeth worn to a point! These belts are tough, but I'll change for that piece of mind.
    Thanks
