Online: Humbug, Soapbox2627
Orange Spark Plug Leads
  • la0055
    la0055
    G'day all
    Anyone running with Orange spark plug leads on a 2007 Sporty? Mine is a 2007 XL883L.
    Not really fussed if 8mm or 10mm, as long as they fit, are reliable, and look good.
    If so, where did you source them please.s
    Cheer
  • Bear2009
    Bear2009
    I run twisted 10mm spark plug leads on my 48 , you can pick them up from fleabay for $59.95 plus delivery from the states
    you can get them practically in any colour , you can also pick up screaming eagle ones from the stealers , not sure on the price thou
    10 mm a bit figgity to put in under the tank where the stock ones go but with a bit patience they go in ok
  • Tzukius
    Tzukius
    I run the SE leads on my 2010 Iron. They look great and work just fine.
  • la0055
    la0055
    Cheers Guys, appreciate the feedback.
    Can you recall where you got your SE leads Tzukius ?
    ICE Ignition make very high quaity and High Performace Leads and sizes, All colours in Melbourne 03 9532 6000
  • Kiwimumbles
    Kiwimumbles
    I put 10mm SE on my iron , just brought them from the harley dealership , weren't all that expensive and the bike seems to perform a lot better too (cleaner spark) just make sure that you get the right model (idiots gave me leads for a DNYA, and they won't fit)
  • la0055
    la0055
    Cheers guys
    I have just ordered a set of Screamin Eagle 10mm Phat from Gasoline Alley Harley-Davidson in Sydney for $27.
    Don't know if anyone else has dealt with Gasoline Alley, but I find that they always have or can source everything I want and their customer service (thru Juanita) is always very prompt and first-class.
  • Rocky2010
    Rocky2010
    Put the SE Orange plug leads on the girls Sporty, look good and they were cheap about $28.00  they dont make it go any better just look better than original thin black spagetti leads :-)
  • JOHNO23
    JOHNO23
     Hi will,
    they look pretty good.
    did you notice any difference with performance?
    Thanks.
  • JOHNO23
    JOHNO23
     Noted,
    thanks Will
  • terroristone
    terroristone
    http://www.hurricaneautomotive.com.au/hurricane-leads-home used these guys many times for leads on all sorts of cars, ranging from stock to 7 second drag cars! Very very good product and well priced.
    T1
