Online: B0nes, Nino
lower ass end
  • masterzink
    masterzink
    hi all,does any one no much about lowering ass end on softail st,and do you have to do the front aswell..is it worth doin or just leave it stock standard..i want it for a better look but dont want to make the ride too uncomfortable.....cheers
  • Aunty X
    Aunty X
    Personally, I wouldn't worry about it, unless you want to scrape around the bends.
  • clubbie
    clubbie
    Nice bike mz and welcome to the forums. Lowering the ass of an fxst (as you probably know) is a piece of cake. Trade off unless you change shocks
    (like Progressives) is a harsh ride and less cornering clearance.
    So the answer is a question. How do you ride? Daily, twisties, country, city, cruise etc.
    clubbie
    Can buy a lowering kit on the cheap on eBay. First sit on the bike and check your clearance between rear tyre and fender as its closer than you would think. Plus u will lose clearance when cornering. I wouldn't do it. Nearly did until I realised my weight on the bike made it lower anyway
  • masterzink
    masterzink
    thanks for the reply guys i guess ill just leave as is cause i do hav passengers on every now and again...cheers
  • Filthy
    Filthy
    Get youself a good set of adjustable air suspension and have the best of both worlds !
    Philthy
    as others have said buy proggessive shocks than you can lower, raise.or stiffen to suit your bike and riding style no point having a 4wd if its not needed
  • Ando
    Ando
    Mate this is mine slightly adjusted lower with the ebay lowering kit, it handles sweet and rides nice, got a few mates that have done the same and ride like cut snakes doesn,t seam to stop them in corners, ohh and my pipe doesn,t scrap
    [/URL]
    thats the best hight there ando ,but you are lucky in the scrape department with that pipe very nice and clean bike
  • Ando
    Ando
    yeh what PH said
    I had those v&h big radius pipes on my fatboy and with just me on board around 95kg, the lower pipe scraped easy so hence didnt want it any lower than standard
  • masterzink
    masterzink
    once again guys thanks for the tip...couple of ideas to think about....cheers
  • masterzink
    masterzink
    allso nic pics for the dudes that sent pics of there ride...very cool............
  • Hooky
    Hooky
    I didn't like the look of the standard clearance between the guard and rear wheel on my softy neither, but i'm 104kg, so it lowers itself when I jump on.
  • the_mongrel
    the_mongrel
     Lower the shit out of it!  Looks much better.
    Here is my Fatboy lowered to the hilt!  Rides fine, and 2 up is fine too.  It's lowered with the easy bolt on lowering kit you can buy.
    This is two up on a recent charity ride.  No dramas at all!
