Online: Nino
Yet more brake questions.
  • ozymax
    ozymax
    2008 CVO springer, single spot calliper on the front which is next to useless. Almost don't want to ride the thing fearing it wont pull up.
    Any ideas on a descent 4 spot that's an easy bolt on?
    It's got a 4 spot on the back surprisingly
  • Retroman
    My 2008 CVO Springer has the same one piston sliding caliper and it's better than I thought it would be !
    There are a number of US brake specialist companies who do a 4 piston bolt on caliper kit
    I just did a net search before I got my Springer and found a few , Hawg halters and others
    The rear caliper is the same Brembo clone caliper as all other 2008 Softails
    The yank CVO forum has plenty of threads on the subject.
  • ozymax
    ozymax
    cheers mate
    been searching and looks like Performance Machine do some but there's debate if it's straight bolt on.
    Rollies is a dealer so might drop in and have a chat
  • Retroman
    Yes , I know what you mean mate about " debate ",
    Some of the instructions I found went on about " shimming" for clearance etc etc
    Left me thinking " I'll give it a try stock..."
    4+ months later it seems OK enough so I have not bothered to change
  • Rocky2010
    Rocky2010
    Why does Harley insist on putting single disk on the front of most Harleys the braking is very poor for a bike of that weight. Harley brakes are very wooden with no fell at all when applying the brakes.
    HD Tourers have a good setup with the twin Brembos up front, it would be good to have those on all of the models.
  • ozymax
    ozymax
    they do it that way so we can spend more $$$$$$$$
    mate I got a 2012 fatbob and it stops real good and has good feel to the leaver
    the springer on the other hand IMHO should not be on the road
    +1 I went from a Heritage to a fatty which seemed to brake a bit better. Then on to a muscle which the brakes were very good to an ultra which again are very good.
    Its all about the coin............ and compromise .....$$$$$$$
  • ozymax
    ozymax
    tried the pads, lines are good. Now you mention it I got a set of new ZZR11 brakes in the shed. Dont want to make it look like an add on so looking for direct bolt up replacement.
    It's a CVO so needs to look like it was meant to be there so the mounting is probably the critical bit.
  • Retroman
    The 2009 CVO Springer has of course a front 4 piston caliper from stock
    Don't know how easy one would be to " match-up " to the 2008 system
    Caliper would be no problem to source , new ones in chrome available from Harley as you'll know !
    Admittedly ( matter of personal opinion here !) the stock CVO 2009 setup does not "look" as good as the 2008
  • ozymax
    ozymax
    2009 is a different axle size so the mount needs to be sleeved to fit on the 2008 axle.
    should be able to sort something out just a matter of thinking it through. I thought that maybe since they were such crap stoppers there might be a kit for a bolt on set up.
    PM looks ok but just need to go see one.
    thanks for all the info guys
  • Retroman
     This is the kinda thing you're talking about !
    I knew I had this photo , sent to me by a guy on the US forums
    I think the brand is Hawg Halters ( from memory !) part number FKHSCC100 it was $375 USD
    This is from 6+ months ago so apologies for any innacuracy due to my " early onset Alzheimers " haha...
  • ozymax
    ozymax
    cheers guys.
    retro that looks like it uses the original mount holes. I thought it would mount at each end.
    Gives me something to consider
