Online: tussuck, fatbat
Push Rod Adjustment
  • the_mongrel
    the_mongrel
     Hi lads,
    So its been about 5000km since I installed the new cams and rods, and am wondering, should I do a Pushrod Adjustment?  And if so, do I just follwow the same procedure as I did when I installed?
    Any tips would be great.
  • ozymax
    ozymax
    unless they were new EMPTY lifters when you installed them.
  • Ando
    Ando
    if it sound alright and runs good don't bother
  • the_mongrel
    the_mongrel
    It sounds a little noisy, but I have nothing to compare it too - so maybe its normal!! Runs like a dream. :)
    If it sounds fine then leave it well enough alone. Spend you time and money on the bits that actually need messing with.
     if they are the 1984 & later stock type hyd lifters with adjustable pushrods & set proper in the 1st place  you never have to readjust
