Online: Nino
Which polished rotors & pads - can you recommend?
  • Maphew
    Maphew
    Morning - posted this in the Softail but figured it may be better over here.
    I'm chroming out my front sliders and would like to fit polished rotors front and back.
    My front rotor feels under spec so I'll simply replace rather than polish.
    Can you suggest a quality rotor and pad, genuine or aftermaket.
    Obviously safety is primary focus, secondary looks.
    Bike - 08 Night train/Softail.
    For pads you cannot beat Lyndall Gold.... About $60-$70 for the front set but man they stick like glue and there is absolutely no brake dust given off.
    Pads I got from Rollies....
  • conmore
    conmore
    Hi there
    A huge +1 for Lyndall Pads. Use them on my Fattie and Bagger. Great pads and literally almost dust free.
  • Maphew
    Maphew
    Thanks for the replies regarding pads, any suggestions as to a polished rotor? Should I just buy genuine?
    Hi,
    Buy a good name brand or OEM. Just be careful about ones that seem too cheap as you have no way of knowing what type or quality of metal went into making them. The quality of the steel in the disk is a major player in the stopping power, heat dispersion and warpability/stability of the system.
  • clubbie
    clubbie
    Matt buy the Harley stuff from Harley Heaven (sponsor on here). You will be shocked at how cheap two chromed floating rotors with new bolts actually cost. Mate just did this on a softie and the Harley parts were cheaper than a well known aftermarket brake supplier.
    clubbie
    And get Russell brake lines! The non-expanding ones made a world of difference to my old Evo.
    got mine from fleabay where on the bike more than 31/2 years no problams and used lyndell pads go with one of the brand names cant remember mine, my new ones on my new ride i got from bkrider
  • Maphew
    Maphew
    Thanks for replies, I ended up with a set of Harley polished rotors which were almost comparible in price to aftermarket (some good, some not sure) brands of rotors.
    Just need to get a set of pads...
    Give Rollies a call if your interested in Lyndall pads. They are cheaper than buying a set overseas via eBay.
  • shingles
    shingles
    welll i l ike yaself wanted polished or chromed rotors looked all over net ended up at sys harley sydney for purchase were cheaper than anywere that i could find for my 08 fatbob ,overseas rotors were expensive  for my bike and hard 2 find coz of floating disc design ,i looked all over da place tons of discs but not 4 my bike ,so rang local shop 300 each no new bolts that extra ,rang sys harley nearly half price and chromed centre and new chromed bolts in deal also bought pads front all up 490 ,new discs chrome ,new chrome disc mounting bolts ,and new good quality front pads 4 2 discs frieght was 40 somethin so 530 to my door for original HD parts ,that was a great price as my shop wanted 600 4 2 discs an that wasnt the chromed discs ,so now all my parts bought sys harley so far unless can find cheaper in oz
  • Rick1310
    Rick1310
     I just got a set of Chrome Classic floaters for the from of my Streety from Blacktown Harley & they were cheaper then aftermarket from MCA. But I did buy the back one from MCA as it does have to pretty as you don't see it & that was only $80 & the fronts cost me approx $320. which was a lot better then MCA.
