106 fat bob dyno run
  • ozymax
    ozymax
    got it on the dyno today and tuned after a week of thinking I hadn't got it quite right
    ran 116hp and 118 ft lb first up
    finished at 122 122 so over all pretty happy with how it came out. about 118 square at the 5200 cut over
    106CI
    CNC ported heads, .045 milled off
    80cc chanbers singh grooved
    woods TW777 cams
    50mm SE throttle body 4.9injecters
    stock headers with cat gutted and flapper removed.
    stock muffler cases with purpose made baffels
     the RED line is from when I had it tuned as 103 with AC and V&H 2:1
  • shingles
    shingles
    geez max thats the way an you did most work yourself dissasembly an reasemble now how does it feel in the seat of ya pants when u twist throttle i know its early days yet runnin in an all ,whats the most difference you can notice strate up more tourque or hp  tryin 2 break wheel tracktion when gently twistin throttle ,are mods what u thought engine would be any way enough of me why dont we get together if possible that is if your down this way i giv u ride mine see how it rides c ya
  • ozymax
    ozymax
    shingles yes all assembly and part selection myself, checked all machine work and had some redone as I wasn't satisfied with the results,
    It is nothing like I was expecting, it is very smooth and well mannered,, I expected it to be more abrupt which is why I didn't think it had turned out right. It was run in the first day mate the only thing I needed to do was bed the rings nothing else in one of these to run in really.
    I just ride it like I always have.
    About the only thing I notice is coming out of corners it's breaking the rear free
    I was down your way kind of Tuesday, through coomera to beachmont to canungra
  • ozymax
    ozymax
    yep looked at that and it's tuned by stroker so there wouldn't be anything left in it.
    and another
    09 Ultra 107 build. Tuned by stroker, machining/headwork by Kirby @ Vee Twin
    so I feel better about mine now but still not happy with it being so well mannered.
    trying to find a AC for the SE 58MM to see what effect that has.
    still got your CR and cam advice to go to as well.
    I think at the end of the day I will get what I want out of it.
  • ozymax
    ozymax
    don't jest been looking at it, already got the clutch and throttle.
  • ozymax
    ozymax
    $6700
  • ozymax
    ozymax
    haha would have been except the mrs went and bought a beemer yesterday
