Online: B0nes, Nino
Looking for dimensions off a 1200 Custom with wide forks/front wheel
  • fizzicist
    fizzicist
    I have a favour to ask from someone who owns a Sporty custom or nightster with through bolt risers with wide front wheel / forks.
    I'm looking to replace my top triple clamp that has integrated risers currently and i would like to install bolt through risers.
    My favour to ask is could someone please measure the fork width and the distance from the centre bolt through the frame to the fork.
    I just want to confirm dimensions before i go ahead and order a top triple clamp.
    Any help is greatly appreciated.
  • Superlow 11
    Superlow 11
    The forks have a different off set on the 1200 custom you will have to change top and bottom clamp, I found out the hard way
  • fizzicist
    fizzicist
    So what was your solution?
    I found a 1200 top clamp at the wreckers but it was too skinny, however the 2011 models - CP and CT have the wide wheels so therefore i'm curious as to whether this is the same width as the superlow. I can imagine it being different but i'm hoping it will fit.
  • Superlow 11
    Superlow 11
    The off set from the head stem bolt and the forks are different on the 2011 custom to the soperlow you can call me if like to find out more (0409003454)
