Online: Nino
Looking to buy first bike
  • Nigel2830
    Nigel2830
     Hi im looking to buy my first HD and just looking for some advice. Im riding about 90km to work of a morning from newcastle to sydney and need a comfy bike and good on fuel to get me to and from work. Any advice would be much really apreciated.
    Height, weight, have you ridden other bikes? That said, the answer is Street Bob or Fat Bob.
  • Nigel2830
    Nigel2830
     Im about 5.6ft and 85kg been riding bikes for years but only dort bikes of road. Been riding a postie on my Ls and Ps as i live in the city but moving to newcastle and will be riding 180kms a day to and from work. Thanks bonkerz
  • terroristone
    terroristone
    Bonkerz is right, if the budget can get you that far...
    T!
  • Sida
    Sida
    +1 street bob. The bigger bike with longer range will suit your riding need better than any sporty (maybe a 1200 custom with a nice seat). Granted at 180ks a day you will probably be hitting the servo every second day, even with a big tank.
  • Dermie
    Dermie
     Yup you'll need to fill up just about every day, I would'nt start out on a trip after having done 180kms in traffic on my 1200c. I would imagine that 5' 6" would be getting down there in heights for a sportster but a "low" sportster might be ok for a smaller rider. I'm 5' 7" 7/8ths & reckon that another 2" less would be a bit small. You can get lowering kits for sportys & they don't cost much. Good luck out there in the traffic.
    PS get onto an advanced riding course, not only do they give you some good riding tips they do drum in good (traffic related) riding habits to live by.
  • southwind
    southwind
    Go ride a VROD and a Street Bob on the same day.
    One has brakes and power and the other doesn't. You can work it out.
    enjoy!
  • southwind
    southwind
     OOps, you might be vertically challenged for the VROD? The ride position is more geared towards taller beings and even with reduced reach seat and bars you still may not be able to make it comfortable
  • Iron Gezer WA
    Iron Gezer WA
    I love my sporty, but I also do around 100 K's a day around trip to work... I'm also around your size and it suits me fine, but I'm having to fuel up on the way home every second day because of the small tank on them, it get's a bit annoying......But I still love it! :)
  • Isaac
    Isaac
    How much you willing ta spend?
    On the height thing there's plenty of Harleys come in ' Low' models. The Deluxe was the lowest seat for years but there's many others now.
    If yur heart's set on a HD then ride as many different models as you can. Your fave within yur budget sets the deal... doesn't everyone do this?
  • Louiey
    Louiey
     Myself I would buy a Haley Davidson Electra Glide but I'm bias.... but a dyna would be more for your height and weight ratio
  • Nigel2830
    Nigel2830
    Thanks guys, im looking to spend between 15k/20k
