Online: devkkumar59
midglide forks on a sporty
  • IronheadAnt
    IronheadAnt
    guys i am trying to find a kit to convert my original forks to what i think i need which is a mid glide conversion.the original wheel hub is 105mm across and the new wheel i would like ti fit is 160mm across the hub.the original forks have a 7/8 neck and fork tubed are 35mm.I am also looking to replace the bars and the ones i would like to use are 37mm where the stems do into the triple trees.If all else fails i will look for a complete set of forks that will house the wheel so if any one knows what yaer and model might accomadate all of these requests i would like to find out
    i can give you AI cycle eng ph # if you can not find it
  • careyman
    careyman
    a bloke at work said you can do this too
