Online: John.R
Brighter Night Rod Headlight?
  • Thomo_Baca
    Thomo_Baca
    Is there anyway to brighten up the headlight on a 2013 Night Rod? Be better off holding a candle up than the standard one
  • hquick
    hquick
    HID's. Awesome difference.
  • Thomo_Baca
    Thomo_Baca
    Just a bulb change is it?
  • hquick
    hquick
    Nah...bit more than that. Need to install the HID control gear (Ballasts, wiring).
    But....it's not difficult...and it's WELL worth it.
    I think the two kits you'll need are about $25.00 each (from memory).
    Read this thread:
    http://www.1130cc.com/forums/showthread.php?t=159822
  • Thomo_Baca
    Thomo_Baca
    For now I've gone with a bulb change. Narva H11 Blue+90 for the low beam, but my backs fucked at the moment and I havent had a chance to see what its like at night yet. Later in the week I should be able to see. Then depending on what its like I'll either go HID or just change the high beam globe as well.
  • oldrlh
    oldrlh
    l've done 3x HID conversions on 3 DX's 55watt turns night -day (a little bullshit there) well worth the effort then even went as far as one on my old FLH as well
  • oldrlh
    oldrlh
    The Dx kits were from bright light auto's in Ferntree Gully Victoria and were supposed to be bike kits but still needed to be modded a little. l still used the factory headlight bucket and used the inside of the airbox and it all looks neat and tidy.The FLH one was a 35 watt kit l found on E Bay for about $40.00 and l mounted it all in the headlight bucket.Hope this helps.Cheers
