Online: Nino
Upper triple clamp needed
  • fizzicist
    fizzicist
    I have a dilemma guys, i'm looking for an upper triple tree clamp to replace the current one on my '11 superlow.
    At the moment it has the handlebar/speedo housing clamp integrated into the triple tree clamp.
    I'm looking for a top triple clamp that will take bolts through the triple clamp into straight risers.
    I've got a set of fat risers and bars that i want to fit to the bike and just need the straight through type triple clamp.
    I bought a clamp off a wreckers from a 1200 custom thinking it might be ok but the fork centres are wrong. (Stupid me didn't measure)
    I need 215mm between fork centres.
    I can't mill the old clamp off and drill new holes as there's not enough meat in the body of the clamp.
    Anybody been down this road before?
  • Superlow 11
    Superlow 11
    I've done the same thing to my 2011 superlow but after doing a lot of home work had to change the top and bottom triple trees of a 2011 , 1200 custom but was well worth the trouble and now have 6 inch rise t-bars it not only changed the look but also improved ride handling and comfort ..
