Online: devkkumar59
Changing Digital Readout on Speedo
  • rix181
    rix181
     I was told that you can change the digital readout on the original Harley speedo ie: clock, oddometre, gear/revs, trip 1, trip 2 & distance till empty,
    as on my 2011 Fat Boy Lo.I'm trading it in on a 2011 Road King and would like to have the same readouts on the Road King.
    IS IT POSIBLE??
    cheers Rick.
  • rix181
    rix181
     The roady I'm getting only has 1 trip no tach and no distance too empty
  • rix181
    rix181
     Ok thanks I'll talk to the dealer and get him to check/reset it
    cheers Rick
  • killerchef
    killerchef
    yeah that's interesting. logic says you should have the same outputs. if the dealer comes up short you may to look at some of the aftermarket ones. the dakota digitals look the goods although freakin pricey.
  • mr.gimmick
    mr.gimmick
     i dont know about changing but originally '11 has got trip 1 and 2, dist to empty, odo and clock. when the light for fuel comes on trip 1 or 2 will change to dte.
