Online: beaglebasher, Hilly
Barn find Fatboy
  • Big H
    Big H
     Found this old 94 Fatty in a cane farmers shed over Easter, convinced the first owner to part with it.
    Now need to work out where to start, some help from this awesome forum would be nice.
    Original owner said she had done 270,000Ks and had not been start in the last 6 years. He rebuilt the top end but got stuck around the cam and pushrods.
    Might be a issue with the ignition as well cause he has that off too.
    My plan is to put some adjustable pushrods in and turn it over slowly listening for weird noises, if all good then connect battery and see how she fires.
    Does this sound like the first thing you all would do?
  • Geoff3DMN
    Geoff3DMN
    The first thing I'd do is remove the plugs and put a little light oil down the plug holes, then I'd let it sit for a day and change all the fluids.
    Then and only then I'd put the adjustable push rods in and slowly turn it over by hand.
    i would do what geoff said but if you have the std pushrods and it is a std cam pull the the top rocker boxes and fit them and see how she is than before you lash out on pushrods ,wish i could find a barn find like that good stuff nice winter project
  • Big H
    Big H
    Yeah I'm a bit unsure about the current pushrods and the cam, the old bloke said he tried to muck around with them and he has left it unfinished. He did say ill need new rods. The top end looks all bolted up new so I'm not keen to unbolt it, that's why I'm thinking about going down the adjustable path.
    Plan will be to drain all fluids Geoff's idea.
    The thing is I have an unknown engine, who knows what's complete without pulling it down and reassembling again.
    even with some brand adjustable push rods you still need to remove / back off the lower rocker box to get the rod tip in the rocker ,i would leave the heads and jugs on pull the cam cover and have a looksee aswell to make sure the breather and cam are timed and may aswell slip the cam out aswell to check what it is whilst your there which you can do with out removing the lifters or lifter blocks maybe even check the torque on the heads as you say you have a unkown engine this where a workshop manual will help you heaps there is a free download in the refrance section
  • 883n Harley Convert
    883n Harley Convert
    Its a great barn find, really great!!
  • Big H
    Big H
     Not going to start until next month cause of work but sitting here thinking about is going to drive me nuts.
    Pulling the cam cover off is the best option and first thing ill do.
    anyone seen a link for a free parts manual? I have a service manual but would love one of those exploded view parts manuals
  • Colstah
    Colstah
    Looks pretty bloody good for a barn find!!
  • Sparra
    Sparra
    How much is a barn find??
  • The Don
    The Don
    Pic of the 94 may not have come through, that's a Twinny and by the signature his current ride.
    he has changed the pic since this was first posted it was a red evo fatboy
  • Big H
    Big H
    The pic has changed, for some reason that is the picture I tried to put in another thread and it showed up here.....weird.
  • Colstah
    Colstah
    Not looking so suspicious now, but still can't see the '94.
  • Burnzi
    Burnzi
    If you go into Big H's "pics" you can see the 94
    Big HUser is Offline
    Stock Poster
    Stock Poster
    Send Message
    My pics
  • Colstah
    Colstah
    Not happening for me there, either, but no matter. Good luck with the 're-birth'...
  • Burnzi
    Burnzi
    Hmmm sorry Colstah if you have no pics in your my pics I dont think you can view anyone elses......I think
  • Burnzi
    Burnzi
    Shit if only I found the Barn find Fatboy and not just the fukn picture of it.......hahahahaha
    http://www.hdforums.com.au/userpics/3463/image.jpg
  • Colstah
    Colstah
    I can see that one! Thanks Burnzi.
    Nice find (depending on the price...of course!)
