Online: Adam76
06 Dyna Running Lean
  • daccadan
    daccadan
    Gooday all I have a 06 Dyna Wide Glide that has hi-flow air cleaner and V&H longshots on it  There is no race tuner/powercommander etc on the bike. I recently had it serviced and was told the motor is running very lean as the 02 sensor was nearly white in the front header pipe. It does run a bit rough around town but smooths out once on the road.
    Local Harley shop says a powercommander and a dyno tune will fix this and make it feel better than new--I dont doubt this but they want over $1000 for this-Ive just about spent my last penny on this bike so far---is there a cheaper and easier solution. I know very little about EFI and these tuners.
    I was running 91 ULP-now am running 95 ULP
    Cheers-Dan
  • Retroman
    Yes mate, what state ?
    If you're in WA I can help
    If you're in the east , than use Nightrider XiED wires , " best tuning bang for the buck "
    Do a forum search for threads on them
  • daccadan
    daccadan
    Tasmania
  • Retroman
    So it's a "Yank grey import" 2006 Dyna . Australian market bikes did not have O2 sensors until 2007
    Look on the Nightrider website at the Ied and Xied wires.
    http://www.nightrider.com/parts/
    There will be an application for your model year and bike
    Around $100/120 delivered from Florida and easy to install
    That's all you'll need mate
