Online: Ronmac, tussuck, Nino
Bar change up.
  • 98superglide
    98superglide
     Hi guys,
    I want to get my bars internally wired, so, I need new bars, they are old anyway. I would pref not to have to replace all the cables etc. im wondering if there is a rule of thumb as to how much wiring etc will be left over? I mean, in buying new bars, short of buying the same size and design, how do Much room would I have to move?
    any help much appreciated.
    cheers,
    ben
  • the_mongrel
    the_mongrel
    If its any help, I put 4 inch risers and my cable fit. :) Now I am running Mini Apes and they still fit!
  • 98superglide
    98superglide
     Thanks mongrel. I have some 16 " rsd apes. Im now leaning towardssome low wide bars to minimise labour and new cables etc.....decisions decisions....
