Online: DIVOT
Help and advice please
  • blubarb
    blubarb
    G'day all.  I am thinking of pulling the trigger on my first Harley, most likely an 883 Sportster with a few small modifications, eg:  seat, forward controls& pegs.  I am looking to buy new here in Perth.  The decision, and I am sure one that you have all faced at one time, is pipe selection.  What I am after is a nice sweet, low rumble with a crack on acceleration.  Fraser's suggest  putting on either S&S slip on mufflers, or a set of Vance and Hines slip on straight shot mufflerswith a High flow aircleaner kit, and a pro-tuner efi kit onto the bike. I was thinking of maybe V & H short shots, but I am unsure about whether I need to be concerned about how much noise they put out, is their a decibel limit to stay within for pipes in regard to WA road regs?  I know it's a personal choice but it's hard as I have never heard two Harleys really sound the same.  Perhaps I should just stay with the standard pipes and change at service after more thought?  Thanks for any ideas.
    Go search youTube for the pipes (on the bike) you're looking at - its not a perfect way too hear them, but it gives you an idea.
  • toxic
    toxic
    I fitted V&H short shot staggered straight from new, the factory pipes will scrape the ground if ya lean far enough, which ain't to hard to do. The dealer will charge like a wounded moose if they do it, get out & meet some forum members & listen to their bikes, that should give you a real world idea of the sound.
    Not sure but I believe most aftermarket pipes are louder than the recomembered level.
  • kingchops
    kingchops
    Blubard,
    Toxic is right any aftermarket pipe is defectable, I've got the Screamin Eagle Street Legal (US) pipes and even they got defected. I've heard the S&S slip-ons and the V&H Short Shots both make a great and pretty loud sound. Haven't heard the Straight Shots but I'm sure they're good.
  • blubarb
    blubarb
    Thanks guys.  Can't wait to let you know when it's thumping in the driveway!
  • Phillthy
    Phillthy
    You can modify the original mufflers by removing the baffle (with hole saw) and drilling out the existing holes in the baffle with 6mm ones and adding extra holes on the out side section of it. Then re weld them back in and you have a better sounding set of pipes that look original.
