Online: HD17
My Build... Slowly getting there
  • DRAIN
    DRAIN
    Havent really made a heap of progress of late but here's a bit of an update.
    Just finishing off some welding before we send off to get painted.
  • Nirvana ride
    Nirvana ride
    G'day DRAIN,
    Just wondering what brakes you used M-cylinders, lines and calipers etc, did you go after market or Harley?
  • DRAIN
    DRAIN
    Havent wrked out the brake sitch yet. Kinda last on my list..
    Mocking up all the stuff we have so far and then doing brakes and driveline stuff last.
    Probably hit up ian at vpw as usual and get brakes and lines etc from him
  • DRAIN
    DRAIN
    when i first got the engine it was in a box of random parts
    Im just going to clean it up spray it black and cover it with wraps...
    i have no idea the brand or year of it
  • TJU
    TJU
    Nice Project Drain ... are you running small springs under the seat ... what colour you going with .
  • DRAIN
    DRAIN
    Im actually going to clean the frame and spray the bare metal clear..
    just gotta clean up the surface rust off and then get it cleared.
  • DRAIN
    DRAIN
    always loved that hammered gun metal look
    ive been tossing up between that or just the raw metal with a clear..
    Going to decide in the next few weeks once we finish up the final welds etc on the frame.
