Online: Far Canal
Speedo from miles to Klm ?
  • Crazy Erny
    Crazy Erny
    Hey Guys, does ayone know someone who does speedo conversions from miles to Klm, or to buy a new or used speedo that is in Klm that will suit a 1980 FXS low rider for rego? Names & addresses if possible & in Qld would be first choice but failing that anywhere will do! :)
  • careyman
    careyman
    I thought the harley dealers did this? its only the plate in the dash? or do they need to change the speedo as well?
    you could ask a quote from one of the sponsors via this thread (they are pretty cheap)
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=9&postid=478503&view=topic
  • Crazy Erny
    Crazy Erny
    Cheers guys, much appreciated.
