Online: Wanderer57
Hint for new Tmax users
  • kiteman
    kiteman
    Here's a hint for new Tmax with Auto-Tune users with EFI late model motors, especially if you're a rank idiot like me!
    What would you do a minute or so after riding off and you look down and see that:
     your speedo doesn't work
    your odometer doesn't work
    the "engine" light is on
    the battery light is on
    the alarm light is on
    your lights work, your indicators work but don't cancel themselves.
    Maybe something under the seat has got itself unplugged and this is my first long ride since fitting. I figured that probably I could stop, switch off, restart and the Tmax would re-read everything and all would be well. Or, maybe a fuse had gone and it's all OK as there are 2 spares in the fuse box or maybe I CAN'T RE-START MY BIKE!!!
    Being 175km from home guess what I did?? I didn't switch the motor off and I rode home and then switched off. Guess what happened then? It started and ran perfectly!!! DUH!!!! and I missed lunch at the pub with all the boys and girls!
    Never mind! I learnt something and it beats the hell out of putting my bike on the back of a truck for the ride home. How embarrassment!! I haven't even got a Yamaha cap to put on....  :))
    I have no idea what caused the glitch but at least the Tmax is smart enough to fix itself!
    Neil (kiteman)
  • PigironBob
    PigironBob
    Sounds like it wasn't initialised properly, you know the 30 cecond on/of 3 times. I beleive after evry time you use the data cable it should be initialised. Other than that F**k knows.
  • kiteman
    kiteman
    Thanks Bob. The bike has done 5 start and stop runs since installation but maybe it's still just learning!!!
  • Iccer
    Iccer
    Hey mr Kiteman, what a predicament that was, to get somewhere for a nice lunch with friends and then to turn around and come home, the right choice was made, you could of turned that rock off and it could of stayed off.
    My T-MAX should be here thursday, my bike should be here next month and i am still not a 100% sure what i am going to fit, i allready own the latest SE race tuner.
    I read you report on the t-max, i can believe you had to take the wheel off and more, Scotty is going to help me when i get it but i dont want him to have to loose a weekend over it, who knows i might end up with the TTS aswell,
    anyway atleast you made it home, the bike is still running.
    No Bike no Sig No CC'S
  • kiteman
    kiteman
    Mr Iccer, it must be a pain-in-the-ass having to remove so much to get at the stock ECM but I don't honestly think there is enough room to fit a piggy-back system (as opposed to a replacement ECM) in there without doing so. I'm sure Scotty will know more about this if he has installed one in a Rocker. My apologies if I'm out of line here!
    It may well be worth the extra time. Just make sure to leave the PC cable attached to the ECM so you can easily plug in your laptop in future if you need to.
    At least the seat comes off in under 5 seconds!!
  • kiteman
    kiteman
    Scotty, is there somewhere in the pdf help file that describes the known glitches?
  • kiteman
    kiteman
    That's quite a coincidence Darkash!!! When you mention "reset the codes..." did you mean that you literally switched off the bike and then re started it or something else???
    I believe that, like home computers, the Tmax re-checks itself every time it starts so maybe that's all that is needed. It's good to know that it's a rare occurrence anyway and that it's a "known quantity"!
  • Fantm2
    Fantm2
    Had my Tmax on for near on a year and haven't had it do any weird stuff .............yet!
