Online: WideglidingNZ
Emergency Roadside Tool Kits
  • 06 Softail
    06 Softail
     Hi guys, a few of us South Aussies are planning a road trip in the next couple weeks, and I was wondering if there was a thread here relating to what essential tools would be reccommended.
    Would HD or other bike shops would stock  tool kits to take with you on road trips.  No one likes to be stuck on the side of the road in the middle of nowhere.
     I have an emergency tyre repair kit that i plan on taking with me, but I sadly can't take my whole tool cabinet  from home with me
    Cheers Ash.
  • blueystar
    blueystar
    Mobil phone and credit card all you need
  • 06 Softail
    06 Softail
     A bit hard if you dont have phone coverage, or credit card.
  • GT 1200
    GT 1200
     Tools?
    They will be the few on the jappas.
    Take some duct tape and CRC. If it is loose, use the tape and if it's stiff, use the CRC
  • blueystar
    blueystar
    Telstra has 97% coverage and the banks give away credit cards how hard is that
  • 06 Softail
    06 Softail
     Not all of us are telstra customers, or like to use credit cards.
  • ozymax
    ozymax
    maybe one of those emergency belt repair kits.
    full and complete going over before you leave especially if you have recently completed some mods
  • blueystar
    blueystar
    If i am in the car the bike or trike.
    My mobile phone and rac gold card get me home every time
    If some thing gose wrong on the road
  • mickle
    mickle
    Always have the credit card and phone then Cargol tubeless puncture repair kit.
  • careyman
    careyman
    dont own a credit card,, never have,,,
    pends where u plan to go to, (how far and for how long)
    harley sells em page 798 2013 cata
    a. H arley-Davidson® Premium Tool Kit
    This Premium Harley-Davidson® branded Tool Kit features all
    the tools you need for common maintenance on your motorcycle.
    The heavy-duty tools are conveniently secured in a
    hinged carrying case, and lock in place for simple organization.
    Tools feature large, easy-to-read size indicators, and are
    stamped with the classic Harley-Davidson script. Lifetime
    warranty.
    64-Piece Kit includes:
    1 – Quick-Release Ratchet (3/8" Drive)
    1 – 3" Extension (3/8" Drive)
    1 – 6" Extension (3/8" Drive)
    1 – Universal Joint (3/8" Drive)
    11 – SAE Deep Sockets 3/8" – 1" (3/8" Drive)
    8 – Metric Deep Sockets 10mm – 17mm (3/8" Drive)
    1 – Spark Plug Socket 5/8" (3/8" Drive)
    6 – Hex Sockets 1/8" – 3/8" (3/8" Drive)
    6 – Torx® Sockets T25-T50 (3/8" Drive)
    2 – Spinner Handle (1/4" Drive) with Adaptor
    6 – Bits (Slotted, Phillips, Torx)
    9 – SAE Combination Wrenches 1/4" – 3/4"
    8 – Metric Combination Wrenches 8mm – 17mm
    1 – Diagonal Pliers – 7"
    1 – Slip Joint Pliers – 8"
    1 – Needle Nose Pliers – 8"
    14900033 $269.95
    b. H arley-Davidson/Snap-On® Tool Kits
    These tool kits were developed specifically for Harley-
    Davidson by Snap-on® to perform the most functions with the
    least amount of tools and weight. Provides all the right tools,
    without compromising quality or damaging your motorcycle’s
    hardware. Lifetime warranty.
    H -D®/Snap-on Compact Tool Kit
    Designed to provide the most tools in the least amount
    of space, this tool kit rolls into a compact pouch for easy
    transport.
    94684-00A $219.95
    Fits ’00-later models (except FXR4 and VRSC™ models).
    94660-98 $189.95
    Fits ’99-earlier models.
    H -D/Snap-on Softail® Tool Kit
    Tailored to the Softail® motorcycle, this high-quality tool kit is
    compact to take anywhere, and shaped to fit Softail models
    equipped with teardrop-shaped tool box.
    94668-00 $179.95
    Fits ’00-later Softail models.
    94661-98 $169.95
    Fits ’99-earlier Softail models.
    c. H arley-Davidson Tool Kit
    This is the ideal carry-along tool kit for your Harley-Davidson
    motorcycle. The kit was developed to perform most service
    functions and weigh as little as possible to keep your load light.
    94819-02 $79.95
    Fits ’86-later XL, XR and ’99-later Twin Cam-equipped
    models.
    d. Tool Kit for VRS C Models
    Designed specifically for the V-Rod® motorcycle, this is the
    ideal carry-along tool kit for your VRSC model. The kit includes
    the metric tools required to perform most service functions
    with the least amount of carrying weight.
    94820-02 Fits ’02-later VRSC models. $89.95
    (note prices are usa, (where they actually put the prices on their catalogue,,, unlike our weak ass bike shops)
  • 06 Softail
    06 Softail
     Hey Careyman, thanks for your post regarding tool kits. I have most of those tools already in my tool cabinet at home.  Bit of a waste of money to lash out $ for tools which I otherwise have.
     All I would really need would be just a tool bag, which can be fitted to the fork legs just below the bottom triple tree.
    Would the likes of Peter Stevens stock just the tool bag on its own?
  • houli
    houli
    a good quality pair of pliers with cutters, fence wire will get you home.......................
  • Nomada
    Nomada
    Softy, I got one of those fork bags couple of months ago from Peter Stevens.
    Was on special but cant remember how much.
    I'll probally take my torx set, small shifter, double ended flat/x screwdriver.
  • blueystar
    blueystar
    Fuck. If you don't want to carry a credit card then carry cash or a cheuge book not rocket science
  • blueystar
    blueystar
    Since when you start wearing underware June you sexy bitch xoxox
  • 06 Softail
    06 Softail
     Cheers Hmmm2, thanks for the advice, I certainly will take it onboard.
  • Sturgis
    Sturgis
     Back in the day - 60-70's and possible 80's I had a pretty full tool kit. With the side car on the Sturgis even had a car jack! Now with the '05 Couch I have the HD tool kit plus tire repair kit + cash/card.
    Break downs are limited in this day and age. Travel with mates and it all works out OK!!
  • 06 Softail
    06 Softail
     Burnzi,  good bit of bush mechanic skills mate, did you tell her that the cow shit would wipe off in the grass if she went for a little walk?
