Online: Far Canal
Twin Can Startup
  • garyzac
    garyzac
    Hi
    I got a 2009 Fatboy.. Its slow to start-up. I thought the twin cams start straight away. Anyone got some ideas?
  • ozymax
    ozymax
    battery condition???
  • adadrian
    adadrian
    harley davidson are the best
    screw the rest
  • garyzac
    garyzac
    No, Battery not that old......Thanks
  • garyzac
    garyzac
    OK Hilly
    You might be right, I don't ride it that much as im near 68, years old, but keep having a ride now & then.......There is a trickle charger connected to my Fatboy,.....Ill charge it more often, see what happens
    Gary
  • ozymax
    ozymax
    If I make it to 68 I wont care if I have to buy a new battery every week if I can still go for a ride.
    Gary it may not be the bat but it's not a bad place to start. Maybe see if you can swap it with the one in the fatty.
    Has it always been an issue or just progressively snuck up on you?
  • garyzac
    garyzac
    Well I order a CTEK smart charger, to replace the trickle charger, already connected to battery (apparently there not called trickle chargers no more). Plus a brand new battery, ill fit these next week. Decided to start from scratch. See how it goes then.
    Thanks for the advice fellows
  • garyzac
    garyzac
    Hi Alan
    No, not the fuel, I got a V Rod also, same fuel in that, no problems with start up. putting new battery in Fatboy  Mon
    Thanks
