Online: Stuart
113 se kit
  • pottsy.r@gmail.com
    pottsy.r@gmail.com
     Getting 113 kit install a dealership question is should i upgrade cranksharft i asked the people at the dealership they said it would be fine lots of guys do it and they dont have any come back i was thinking while the motor is out and cases getting bored if i have to spend and extra grand for the piece of mind i will but if i dont really have to i wont any comments from those with the experience would be great thanks
  • KiwiRob
    KiwiRob
    If you have the '07 and later crank with the tapered pin end con-rods, then I'd suggest getting the rods replaced with after market rods + plug and weld crank pin. - Rob
    pottsy.r@gmail.com
     kiwirob do you know of any one in aus that does that cranksharft work
  • Ando
    Ando
    get hold off an S&S crank
  • KiwiRob
    KiwiRob
    I re-call someone mentioning a place in Oz that does crank mods. A forum search on this site may help. - Rob
