Online: Stuart
Shorter risers?
  • terroristone
    terroristone
    You should have checked out Joker Machines website first.  Sell that clamp off and get this :
    http://jokermachine.com/products/harley-davidson/handlebar-clamps-risers/led-handlebar-clamp.html
    This clamp has included risers that are the lowest i have seen.
    The next best thing would be to fit Sportster 48 trees which have a casted in clamp..
    T1
  • ConR
    ConR
    Cheers man. Now I'm debating going with a set of clubmans instead haha. Just not sure if my back will cope with them and forward controls!
    Those Joker ones are pretty sweet though. I guess the other option is can the top clamp, replace it with low risers like the Biltwell ones, and get the side mount speedo with built in signals.
  • terroristone
    terroristone
    if you do, might be a good idea to wear a full face as you might loose some teeth on the tank over bumps! :P
    T1
  • ConR
    ConR
    That's part of riding a Harley no? ;)
