Online: bikenut57
Andrews N6 Cams
  • 45WL
    45WL
    Managed to score myself a set of 2007 buell xb1200r heads and jugs off fleabay. I had the heads setup for Andrews N6 cams.
    There are 2 types available - the first up to 99 model which has the courser gears and 00 and up which have the high contact ratio (HCR) finer gears. I been told that the older courser gears are stronger but why did they change to the finer gears??? Are the newer finer gears quieter?
    Which type would you recommend? and why?
    Thanks
    45WL
  • 45WL
    45WL
    Hmmm
    Did you go for the courser or the hcr geared cams?
    Thanks
  • 45WL
    45WL
    Thanks hmmm
    Just noticed I spell like my ar$e coarse of course!
    if your not going too race it the later gears will be fine  the N6 are a very radial cam lobe & are kind too the valve train  even in the higher rev's  & are only 500 " valve lift
  • 45WL
    45WL
    DR
     I intend pressing the original pinion gear onto the new No 2
    Would you recommend the HCR or the coarse gears? NCR quieter?
    Thanks
  • 45WL
    45WL
    Sorry typo
    HCR quieter?
    Thanks
    45WL
  • 45WL
    45WL
    hmmm
    did you pressout the original pinion gear to replace the one on the No 2 cam or did use the andrews supplied cams as is?
    Thanks
  • stev0
    stev0
    Whichever ones you go with it's a good idea to spend a bit extra and get the later oil pump drive gear. I've come across a few failures in recent year.
  • 45WL
    45WL
    Thanks stev0
    Its on my list but I'll only order the part after I open her up and see what I find.
    NHRS and Hammer Performance both carry bronze parts, although at $99 US + shipping they expensive
