Online: Soapbox2627, HD17, Hilly
Head work
  • gragra38
    gragra38
     Can anyone recommend some places in Melbourne to get some good head work done on a twin cam, I'm in sth eastern suburbs, but don't mind traveling to get work done,
    Cheers,G.
    Give the chaps at Doc Hogs in bayswater a call.
    Also Eastern Big Twin Performance are in the same area and are site Sponsors.
  • gragra38
    gragra38
     It's an '02 wideglide 88 ci, that I'm upping to 95, some cams and want a bit of head work to top it off.
  • gragra38
    gragra38
     Thanks tussuck, I'll give me a try, didn't know doc hogs did that kind of work
  • rodrocket
    rodrocket
    do any of these shops have a flow bench or is it all guess work & what ever looks good should do
    don't mean to sound negative but if a jobs worth doing its worth doing properly
    regards
    Rod
    great info...thanks Kiwi!.
    your most likely right as most of the shops i have been in do not have the gear i would expect them to have for any serious engine work - milling machine etc etc
  • gragra38
    gragra38
     Thanks Kiwi and dyno, the moorrrabbin one is close to me so I might check him out, failing that the beacons field guy sounds good too, geelongs a bit far but thanks for the info anyway.
    Ps. Raino's business next to c& c in Dandenong has closed down, a sad day I must say.
  • ozymax
    ozymax
    dyno that's gotta be above 210 CCP and still close to 10:1 corrected. how is it on the starter?
  • ozymax
    ozymax
    no doubt you have decomps but that's still gotta be hard on the starter I would have thought.
    98 would go with out saying
  • Ando
    Ando
    Fuck yeh chain drive set up
    John treese would be good & in melb.
  • gragra38
    gragra38
     Dyno, sounds like you have some serious mods done to engine, I've been looking at the Woods cams they seem to look pretty good, how have you found yours? Did you get it from US or a dealer here, are you runing aftermarket came plate, oil pump, maybe we could meetup some time and talk engine mods over a bourbon or two, the more people I speak to the more I learn, cheers, G.
    +1 for John Treese
    was talking to him a few weeks ago  & yes he is still working  doing heads
  • Ando
    Ando
    Still like to see the dyno sheet and no wether you had andcrank trued and welded
  • gragra38
    gragra38
     Not a problem Crownies it is,
  • carbon fibre
    carbon fibre
    Got a set of Woods 9F's , been sitting in the cupboard for over 2 yrs now.
    Noisy, hard on valve train. My 107 @ 10.8:1 comp and R&R heads made 116hp.
    Always wondered about these 103,106 and 107 builds claiming 120+hp. Not entirely realistic is my opinion.
  • carbon fibre
    carbon fibre
    I just bolted a set of R&R's latest heads to my engine, changed out the HPI 55mm for a HPI 62mm, HPI 6.2gps injectors, added 1.7 ratio rockers on the inlets. S&S 640 gear drives.Needs to be tuned now.
    With old style heads at 11.75:1 comp, we went 135/130. I'd expect the new combo at 11.5:1 comp to reach 140hp.
    Seems you n I have travelled a similar path.
    My engine is a S&S 4.5" stroke with an Axtell 4.125" bore= 120ci
    I do enjoy tweaking the engine, gets pricey though.
  • capri_v6
    capri_v6
    Hello all
    would any of the above do manual compression releases?
    Gonna go 10.0:1 on a 103 and thinking I'd rather b safe then sorry!
    thanks
    Ben
  • carbon fibre
    carbon fibre
    Yep, latest heads with revised port design and 2" inlets
