Online: Stuart, Hilly
fat boy wheels
  • potluk
    potluk
     Hi guys        I recently boght a set of 39mm wide glide triple trees for my dyna but after installing them i didnt like the result too much so i removed them. A mate gave me a heap of old ozbike books the other day and in an edition from 1993 was a picture of a bike a dealer had put together wich was basically a dyna with a fat boy front that they were selling as a dyna bob. so i am wondering if the axle and wheel from a 93 fatboy would fit on the wide glide set up i have and would the twin disc brake line up properly as i would like to retain twin disc. Below is a picture of the bike although this one is not twin disc.                           Thanks
  • 883n Harley Convert
    883n Harley Convert
    In short, it should. You'll need to check the diameter of the axle and ensure that your bearing and inner spacer suit the axle size and I reckon you're on your way!
    Harley used 3/4 Axle up to 2006. 2007 then they became 25mm
