Steve Cole
  • Ando
    Ando
    I have a new TTS unit for a mates 2012 Fatbob
    My laptop doesn,t have a disc drive, I loaded my version of the TTS disc by saving the disc content to a thumb drive then loading it to the laptop
    with the new version I can,t seam to get it onto my laptop
    Steve how can I get this done
    cheers in advance
  • MADOGA
    MADOGA
    have you tried downloading the latest software from http://www.mastertune.net/downloads.htm
  • AJ56
    AJ56
    That won't work as the website doesn't have the master tune software.
    Best thing is to create a Disc Image of the TTS Disc then load that onto the laptop via the usb. Then find the installation file and run that.
  • Steve Cole
    Steve Cole
    The best way to handle this is to use all installs from our Web site
    Download and install this file on your machine "tts_software_updater-setup-121.zip"
    Once that is install just run the updater and "checkoff" the program you wish to install on the PC and your good to go.
  • Cartoon Head
    Cartoon Head
    Ando, My Mrs mini laptop is the same so we got a cheap USB external disc drive for about $15 off ebay.
    Prior to that I had to save all programs on a zip drive and then transfer them over.
