Online: tussuck
Making an AC for touring work on a softail
  • Dan
    Dan
    I ordered an s&s twin air cleaner for my fatboy & bugger me its for touring models & it seems that the spacer plates are different or the throttle body arrangements are different
    yeah, probably partly my fault for not double checking but I assumed I would recieve the correct part considering the rest of the stuff I had come with it
    So I may be stuck with it
    Is there any way I can make it work to save the hassle of sending it back & waiting for another one?
    many thanks
    Dan
  • wayco
    wayco
    hi Dan,
    I have a a s& s twin air cleaner,& when i got mine it is actually made up of 2 kits-1 for the particular motor set up -ie cable ,drive by wire ,carb ,etc & 2 -the actual air cleaner set up .
    They were about $250 a piece a few years ago ,so if you can't get the engine part of the kit replaced you haven't done all u r $$.
    Depending where you are I may be able to help by looking at mine -07 duece ?
    Cheers Wayco
  • HogBag
    HogBag
    S&S makes a 1/4 inch spacer kit to suit the teardrop backing plate on the delphi body. I will find a link and post it
  • HogBag
    HogBag
    http://www.youtube.com/watch?v=iLcBzfR11Wo
  • Dan
    Dan
    Thanks for that HogBag, unfortunately it looks like it won't match up to the twin AC
    Appreciate the trouble
