Online: baldy1450
Painting or powder coating chromed parts
  • houli
    houli
    Yes its very durable, and if you get sick of it you can paint strip it off.
    yep thats what thay do i had a set of bars and some chrome parts that was slightley rusting done a few mths back if the chrome is still good light sandblast than color over the top
    a coat of etch primer and then black wrinkle paint!....It will look awesome.
    i think they need to light blast 1st  or bead blast so it will stick proper
