Online: baldy1450
Mobil Vtwin in all holes
  • sambeak
    sambeak
    Has anyone been using mobile 1 vtwin in all the holes.  Is this a good thing or a bit risky. Anyone have any thoughts on using different oils as against the same all through  (Heritage Softail 2008)
    Thanks
  • MADOGA
    MADOGA
    I'd suggest against using mobile 1 Vtwin in all holes, should be alright in a motorcycle i guess,
    personally i like the glow in the dark lube from coles for holes .
  • sambeak
    sambeak
    Thanks folks I read somewhere that itd be ok - maybe not
  • Retroman
    Mobil 1 V-Twin in the Engine oil tank no worries , maybe 3 Quarts required
    Mobil 1 V-Twin in the Primary case no worries , 1 Qt required
    In the transmission (AKA gearbox !) I'd put a gear oil , Mobil make a synthetic that comes in Qt bottles ( or maybe 1 litre in Australia !)
    There are many gear oils , Redline " Shockproof heavy " / Amsoil " Severe gear " and many others.
  • mickle
    mickle
    Engine and Primary but Redline shockproof in the gearbox,once you try this in the gearbox you wont use anything else.
  • sambeak
    sambeak
    Thanks Mickle I'll continue to use the mobile in engine and maybe continue with harley oil for Primary - REdline shockproof I haven't used yet but would like to feel that it may improve the clunkiness of my box.Does it help much. I did mention to the harley repairers when new about the clunk but was told "they are pretty agricultural' I took this to mean 'live with it'
