Online: B0nes
I'm looking at purchasing a new 2013 fat bob, and looking at a cam kit for it any suggestions would
  • Dirtball
    Dirtball
  • mickle
    mickle
    Hello and welcome, you will need more than a cam.
  • pat
    pat
    Look up tw-777 woods
    That stock pipe has a cat in it just after it goes into 1
    decat? But 2 into 1 more for tq which pinches hp a bit
    tuner
    air cleaner
    His cams are not cheap.......
    Check warranty issues !!
  • ozymax
    ozymax
    pipes, A/C and a good tune are only going to get you about 85hp.
    as said above cams, compression and heads will help
    may need throttle body and injectors
    then you'll need to think about a clutch and oil cooler
    have a look at the stage 4 thread
  • Dirtball
    Dirtball
    Cheers for reply guys, well was looking at screaming eagle intake Vance and Hines long shots or short.thoughts? Then was going to start with cam heads??
  • nhb006
    nhb006
    SE211's, 30thou head gaskets, decent 2:1 pipe, A/C, and a very good tune you'll be over 100hp/100tq.
  • Dirtball
    Dirtball
    What is that clased as what stage mate ??
  • nhb006
    nhb006
    Cams for most people would be stage 2.
    Heads / Head work for most would be stage 3.
  • Darke_peak
    Darke_peak
    I will let you know next week after i have mine dynoed. i have the 2013 switchback with SE204 cams, full D&D Fatcat 2-1 exhaust, SE air cleaner and power vision tuner. No other engine mods. I'm expecting around 100 hp. The dyno tuner did a street glide 2 weeks ago with same sort of setup and it cracked 100 hp.
  • gragra38
    gragra38
     Mates 2012 fat bob has s&s 583 cams, se air filter, v&h long shots , se tuner, 104 up + 113 torque, so it is possible with not much work.
  • gragra38
    gragra38
