Independent Harley mechanic Melbourne
  • youngbull
    youngbull
     Hi guys
    can anyone recommend a good independent mechanic outside of expensive Peter Stevens chain?
    What part of Melbourne?
    Doc Hogs in Bayswatervhave treated me well in the past. HD Dev in town know their stuff too (I found them pricey but they are good)
  • youngbull
    youngbull
    I live in bayside, closer to inner city would be great
  • terroristone
    terroristone
    i do work from home if interested pm me.
    Regards Andrew - T1
  • youngbull
    youngbull
    Cheers boys, I ended up taking to Colt at HD Dev on Thursday, worked out well as I work in the city and dropped it off in the morning and picked it up at the end of the day.
  • houli
    houli
    Did you feel like you been mugged?
  • youngbull
    youngbull
    Hey Houli,
    Not really, it was $100 less than quotes from Heaven and City. It's still a lot of money I feel to change oil in 3 holes, sparks and go over the bike. But what the options? And these blokes really know Harleys.
    To ride for an hour across town to weribee or fern tree gully to save $70-$90 and kill the whole day is not worth it for me.
    There are not enough choice and completion hence prices are high.
    The next oil change and filter one of my mates will do for me at his house.
  • terroristone
    terroristone
    Just make sure your mate goes over everything, Harley's are renouned for bolts coming loose. An experienced mechanic should know which ones are common etc. I have found almost every bike I have seen for the first time I end up spending atleast an hour going over bolts and finding so many loose. This also includes neck bearing adjustments, I cannot believe how many of those I find under adjusted!
    T1
    Good to hear it turned out okay....like i said, HD Dev have been doing harleys for years and know their chit.
  • fatty2014
    fatty2014
    gday mate looking forsomeone to install aftermarket jay brake forward controlls to my 2014 fatboy are you able to get back to me with a quote for the install
  • thegent
    thegent
    CandC in Dandenong have a new workshop, the mechanics there are great.  If anyone knows Marty they will know how good a mechanic he is..And a top guy!
  • youngbull
    youngbull
    Hey Thegent, how you ben man? when are we goin for a ride together again? My low back has been real shaite, I have not been abe to ride much.
    Where is mechanic in Dandenong? what the busuness name? my mate needs to service a sportster
    I am in Melbourne now after a ride around Victoria turned sour on account of a mate's bike playing up.
    My bike is also having a couple of minor dramas with a check engine light, high idle, a few bolts that have vibrated out and lost and a speedo I can't get working again. I dont have my laptop and diagnostic cable with me to check the Fault code/s I'm staying in Kew for the night.
    Harley heaven in ringwood might be the closest. Where else is around as I need to get the bike sorted tomorrow?
  • Wimbo
    Wimbo
    Terroristone is a Forum Sponsor.He's in Melbourne West.
    Check the sponsors out first blokes.
    Seriously!
    In Bayswater you will find Doc Hogs...damn good crew there!
  • fatty2014
    fatty2014
    Hi can you give me Jeff number looking for a good mechanic
  • GGUser244
    GGUser244
    4 years ago
    Hi I want to modify my harley I live in Melbourne in western suburbs if ny1 can help me .
    I wanna change the bike colour handle bars n risers .plz msg me on my no is 0420 388 842 sid thx.
  • steelo
    steelo
    4 years ago
    Welcome GG. What sort of bike do you have. What is it you want to do to the bike. You may be able to get away with saving yourself some money by doing it yourself.
