Online: Stuart, Hilly
Rear Footpeg mount - Dyna Wide Glide 2012
  • TieriGT
    TieriGT
     Does anyone know of a better bracket for mounting the rear footpegs on a Dyna Wide Glide 2012.  I have put a Vance and Hine big radius on the bike and now the rear footpeg bolt sits very close to the exhaust.  I have raised the bracket by inserting spacers (washers) on the part that bolts on to the swingarm, this is not ideal.
  • clubbie
    clubbie
    The pipes should have come with a block spacer to raise the peg away from the pipe or they are available from a dealer, but then the the raised pegs hit the guard if you anything other than the std length shocks I'll try get a photo for you.
  • rider
    rider
    It's a Widey,,,, so better still loose the rear footpegs !
