Online: Stuart, Hilly
2011 FXDC stopped and wont start
  • JimmyMc
    JimmyMc
    I have a 2011 FXDC, I was riding home and the engine light came on and then stopped. Now it will turn over but wont start. I have got the codes
    P0261 front injector open/low efi
    P2063 rear injector open/low efi
    P1003 system relay contacts open efi
    U1016 loss of ecm serial data
    Can anyone help with what the fix is for these.
    Thanks
    jimmy
  • carbon fibre
    carbon fibre
    P1003 is system relay contacts open.
    Pull fuse cover and replace relay closest to fuses with a known good unit. Try to start. Maybe grab one off a mates bike to try
    One question, does the fuel pump prime when you push the run button.
  • JimmyMc
    JimmyMc
    Hi carbon fibre,
    I couldn't ear the fuel pump priming, which i thought was strange. I might have to find some one with bike a can steal a relay off to try.
  • carbon fibre
    carbon fibre
    Should be able to get a matching relay from any auto store. Take it with ya and try n match if needed.
    Relays are about $10 so no big investment.
  • taff60
    taff60
    First, pull the large fuse, big bugger about 30mm across green from memory. That will clear the 'ser bus'error. Now make a note of the codes and clear them as described many times here.
    See how that goes. Mine is an 04 carby, but it throws a few codes, particulaly when it backfires and stalls due to open pipes. It also doesnt like a quick stab at the starter button either, but thats a different code. This may just get you going again . Recheck for new code after a short run.
  • JimmyMc
    JimmyMc
    Got hold of a new relay the black one. replaced and away she goes again. Thanks for your help guys. I spoke to a dealer today about the other code for the ecm and was told that this would come up if the bike is turning over and wont start.
    I am glad it was only a easy fix.
    Thanks again
