2011 FXDC stopped wont start
  • JimmyMc
    JimmyMc
    I have a 2011 FXDC, I was riding home and the engine light came on and then stopped. Now it will turn over but wont start.  I have got the codes
    P0261 front injector open/low efi
    P2063 rear injector open/low efi
    P1003 system relay contacts open efi
    U1016 loss of ecm serial data
    Can anyone help with what the fix is for these.
    Thanks
    jimmy
  • fat103
    fat103
     Gedday JimmyMc !!
    I gotta 2011 FXDF that threw up similar codes wich led me to the "system relay" and "starter relay" Turns out the black relay was stuffed from taking in water. Replaced them both black and grey and problem fixed !!!! $16 for both from HH. Hope this helps ya out bro !!
    Cheers Kev
  • pat
    pat
    Does your fuel pump kick in and stop
    Or keep running?
  • carbon fibre
    carbon fibre
    Ol mate has posted this thread in w/shop also.
    Already stated pump not working.
    Hate it when they do double threads.lol
  • JimmyMc
    JimmyMc
    Rodder, it is a bit hard for me to drop into a dealer as the closest dealer is 1800 km away, I live in Port Hedland WA. so not so easy, I will be calling them tomorrow to see what they will do but it is sounding like an easy enough problem to fix, well I am hoping it is.
    Sorry Carbon Fibre for putting it up twice, wasnt sure which would be the better place. as not everyone looks in all sections and threads. but thanks for your help also.
  • taff60
    taff60
    Check my post on ur other post. May help'ya get going,
  • JimmyMc
    JimmyMc
    Got hold of a new relay the black one. replaced and away she goes again. Thanks for your help guys. I spoke to a dealer today about the other code for the ecm and was told that this would come up if the bike is turning over and wont start.
    I am glad it was only a easy fix.
    Thanks again
  • carbon fibre
    carbon fibre
    Sweet
    Might pay to get a spare one, as they're cheap. Get some dialectic grease and cover terminals to keep the green death at bay. Always a good service job to pull all fuses n relays n recoat with proper grease.
    Glad it was an easy fix, especially being up in Hedland.
  • amcchucky
    amcchucky
