Online: Soapbox2627
Buddy seat fittings
  • sydneypom
    sydneypom
    Does anyone have a set of fittings for putting the original seat back on my 67 Duo Glide ? I need the T piece, helper springs (with the straight bar) and clip that holds the springs to the rear guard when folded down. Any or all would be appreciated. If anyone does drop me a line.
    Thanks
  • houli
    houli
    Pacific HD or Redgraves would have the lot, very hard to find, the springs fold up under the seat not onto the guard like a pre 58, last duo glide was 64, 65 was first electra glide, do you have the footrests?
  • sydneypom
    sydneypom
    I was in Pacific HD last thursday...and in Redgraves last friday....neither have the kit unfortunatly !!.........but have located an e'bay seller in the states who has the full helper spring kit NOS for $50, great price, just need the t piece,
  • carbon fibre
    carbon fibre
    Try olddude.com, most serious restorers in USA refer to him.
    Vtwinmfg.com will definitely have a reasonable replica and JPCycles.com will definitely have semi reasonable " made in Taiwan" part.
    ps. I thought the Duoglide finished in 64, in 65 they were became electraglide ???
  • sydneypom
    sydneypom
    Yep...........you are right. I had in my mind that I needed to get the helper spring bar that was straight and that was on the duo glides, not the one with a kink in the bar on other models.
