Online: Stuart, Hilly
Glasses advice please
  • Stevieboy34
    Stevieboy34
    Hey guys, my first proper post on here so be kind haha.
    Picked up my bike yesterday (first Harley) after having some work done to it and I tried my face mask on the way home. Its great for keeping the wind off your face of course but the problem was it seemed to deflect the wind straight under my sunnies which do probably sit about 1 cm off my face and it made my eyes water really badly which was really annoying.
    What is the secret I am missing here? Do I need a different set of sunnies and if so can you recomend some or any advice would be appreciated?
    Cheers Stevo
  • AJ56
    AJ56
    Padded Goggles. They will help reduce the wind. Plenty of makes out there..
  • FLSTC
    FLSTC
    any "snug fitting" glasses should be fine .
    btw my personal preference is ugly fish . They are not horribly expensive which is good as I usually go through a pair every year .
  • IR0N
    IR0N
    Yeah UglyFish are the way to go, with the gasket behind the frame you cant go wrong!
  • Stevieboy34
    Stevieboy34
    That is awesome guys thanks for that. I will def get a set this weekend.
  • chopa
    chopa
    Hey Borisat How are the prescription lens with the ugly fish? Did you get the frame that goes on the inside of the sunnies?
  • Aunty X
    Aunty X
    Try Leader glasses. They can fit a lens anywhere up to -6 . The style in particular is the Leader Cruiser. Lens is polycarbonate and can be purchased online for about $250.00 shipped from www.sports-eyewear.com.au . Hope this helps
  • 308bever
    308bever
    go the ugly fish, they are great (((-;
  • Stevieboy34
    Stevieboy34
    Just to update I got the Ugly Fish. Not sure which exact one but they were the biggest style so they fit my schnoz better. I bought a 3 pack which has removeable arms with clear, yellow and tinted glasses. I wore them this morning and they were awesome, a massive difference and I would highly recommend them.
  • mickle
    mickle
    + one for the Uglyfish.
    Fucked up there, meant to say Fuglies.
  • conmore
    conmore
    Hi there
    I have the Ugly Fish Ultimates (3pack) with prescription inserts. Have 2 pairs 1 for the bike and 1 for the car.
    Luv 'em!
  • bahl
    bahl
     Ugly fish it is then
  • 06 Softail
    06 Softail
     I have 2 pairs of scope safety specs with foam already attached & removable wings. 1 pr tinted, the other clear. $20 each from safety workwear shops, I swear by them and use the head bands supplied to keep them firmly on my face.
  • the_mongrel
    the_mongrel
    FUGLIES FUGLIES FUGLIES!! Much better than Ugly Fish!! Fuglies Mongrels are brilliant!! Impact resistant too. I was an Ugly Fish fan for ages, but won't go back now. I have seen the light!!
    The Mongrels are down the list on this page.  Cheaper than Ugly Fish too!!
    shop.fuglies.com.au/polarised_safety_sunglasses.html
