Online: HD17, brucefxdl
Gday mates.
  • Necro
    Necro
    Bit of a newb here,Havent ridden for about 5 years,Last bike was a 2001 wide glide,loved that bike more than my woman,Totally hooked on twin cams since owning that bike,anyway decided To have a crack at building a bike so i am in the process of importing an Atlas frame and planning on buying a stat writeoff dyna  and making a sweet custom dyna running a twin cam driveline,well better start reading as there are a hell of a lot a good threads on this forum. Necro.
  • Fatman
    Fatman
    Welcome & good luck with your build.
    Welcome and good luck with the build Necro .
  • coffee guru
    coffee guru
    Welcome and good luck!
  • DYNA12
    DYNA12
  • Necro
    Necro
    Thanks for the warm welcome guys,Frame is being built by Atlas right now and will soon be on it's way To chopweeza's Depot in cali,according to google it's a 1and 1/2 hours trip How is that for luck.
