Online: Nino
Fuel Range
  • Party
    Party
     Filled the bike up friday morning took it for a run south couple hundred ks. How accurate is the range on the speedo? Reckons i can do 400 to the tank, which is not too bad
  • Party
    Party
     Yes well i havent actually got 400ks yet but thats what the range says. Around town though bormally about 300. Heading down to brizy later in the year cant wait
    I get 400 out of the Ultra no probs but i doubt you would get it out of any of the non tourers, My 04 Heritage got 350 max, the 07 fatboy got 320 max and my 09 Muscle got about 260 max.
  • chriso
    chriso
    400 ks on a tourer? maybe.... I question anyone getting 400 out of anything else. i never heard of it anyhows.
    Range gives a rough idea and thats about it
    Size of tank , divided by .055 (for 5.5 litres per 100kms, about average) .19 litre tank equals 345km .
  • ozymax
    ozymax
    6.6l/100 = 285 dry
  • killerchef
    killerchef
    yep i usually start looking at around 280. did run with some of the wa boys on weekend. 279 all country & pretty much rolled into dwellingup. ; )
  • Aunty X
    Aunty X
    5.5L/100km is what I'm getting on a 103ci . Mostly highway.
  • galbo950
    galbo950
     Managed 346km today on 17.6 litres. That's was including a few ranges, hills and twisties.  It's an 07 FXDWG 96cu with 2 into 1, stage 1 Arlen Ness air cleaner and a dodgy Arlen Ness Big Shot piggy back tuner. I was told it'd never get anymore than 270km before I had to start pushing so I was a little nervous waiting for the next servo.
  • Ando
    Ando
    I have gotten 320ks out the tank with the 120r drinking from it
  • shingles
    shingles
    well i hav once rode 320klms on 1 full tank wen fatbob was in 96ci arangement but usally would fill around 280 mark 2 be safe ,1 day was headin 2 shoot clays was readin 280ks on dial no worries saz me dun 320 once well at 295ks bike she no go proper and i goes u idiot u jus went past garage  few ks ago fuk giv it a last big lunge rokin side 2 side pull of 2 edge of m1 change down giv another lunge pull clutch in an jus let er roll wen slowin 2 much another lunge pull in clutch garage not far now jus gotta get up exit incline but alas ,she no go now well here goes push up exit with my 1 good leg tryin not 2 fall over can see garage jus gotta get 2 top of exit after a few stops got 2 top then rolled into fuel stop buggerd ,so yep u mite get so many ks one day & next time not as many ks as last ride so either test an see how far u go till stopped have fuel in container so u can ride 2 garage to fill then u will now should get x ks before empty .Well now i hav changed my engine a bit an usally 200ks i will look 4 fuel ,this is all hard rideing so fuel doesnt go far,but last week i rode on m1 at constant well sorta constant speed and did 170ks an still had 3bars lit up on fuel gauge flush cap ,could av done another 60-80 ks i rekon this is most ks on one tank since motor upgrade as normally im jus flat out up threw gears an generally floggin it on not so long rides ,constant hwy ride was best ks per tank ive got yet so there ya go ,only thing wrong with long rides 4 me is my foot an knee tends 2 kill u wif utmost pain unbearable i couldnt move much after i rode bak let alone walk it took 5 days before i felt sorta betta an thats wif a ton of meds even that didnt do much 2 stop pain wen riden didnt think i was goin 2 make it 2 home thats how bad this injury is a lousy couple of hundred ks an im fuked 4 a week but did get betta fuel mileage on that more constant ride SHINGLES
  • cford
    cford
    Average 330km - 350km
    Fat Boy Lo 103ci  SEPRT 211cams V+H Big Shot Staggered Stealth Air Cleaner Batwing Fairing.
    On long runs (2k - 3k in a weekend) cruise at 135k (3000rpm)
  • Derek.1966
    Derek.1966
     Average 320 from a 2008 Fatboy (with a fatboy riding...).
  • chrise1961
    chrise1961
    My '11 Heritage gets to about 270-280 and I get nervous so top up time...
    270Km - 290Km (6.6Litres - 7.0 litres / 100K) on a 2010 VRSCF Muscle.
  • DYNA12
    DYNA12
    Here's what I am getting out of my 2012 Wide Glide. When the low fuel light comes on it takes about 12 litres, so still have approximately 100k. It certainly uses less when cruisin the highway. Tank 13 was from the ride to Yarloop.
    I log the the fuel usage every 4 or 5 fills, or when I think about.
    Tank Km Litres Km/L L/100km m/gallon
    1 247 12 20.58 4.86 58.14   Km/17litre  350
    2 284.3 13.29 21.39 4.67 60.43   Km/17litre  364
    3 296.6 13.6 21.81 4.59 61.61   Km/17litre  371
    4 262.3 12.6 20.82 4.80 58.81   Km/17litre  354
    5 200 10 20.00 5.00 56.50   Km/17litre  340
    6 300 13.18 22.76 4.39 64.30 Fuel after tuner, A/C, SE Mufflers Km/17litre  387
    7 292 13.18 22.15 4.51 62.58   Km/17litre  377
    8 201 9.09 22.11 4.52 62.46   Km/17litre  376
    9 246 11.5 21.39 4.67 60.43   Km/17litre  364
    10 248 10.93 22.69 4.41 64.09   Km/17litre  386
    11 253 11.7 21.62 4.62 61.08   Km/17litre  368
    12 291.6 12.22 23.86 4.19 67.41   Km/17litre  406
    13 227 9.2 24.67 4.05 69.70   Km/17litre  419
    14 276.3 12.45 22.19 4.51 62.69   Km/17litre  377
  • clubbie
    clubbie
    320k easy riding open road, light comes on about 300k and out of fuel 40k later.
    City riding lucky to see 200k from a tank.
  • Nomada
    Nomada
    I'm planning on running my 1200 sporty till the first cough.
    12.5 tank, , powervision improved standard tune, straightshot exhaust and on 210 city KLMS at the moment.
    Think I'll take some fuel in the bag to work just in case.
    Ok Everyone. When you're near the end of a tank, if possible take a two litre bottle of fuel with you until it coughs and farts when you know its about to stop, and record your tank reading to see what you get.
    Obviously this will not appeal to everyone and make sure you are within range of a servo, but a few adventurous types might give it a crack and post results back here. Derrr.
    We all know what spirited wrist twisting does so maybe ride sorta normally or even efficiently should i say just to see we can achieve.
    Sound good?
    I am already on 360ks in this tank so i will take a bottle with me next ride to see what i get.
  • Maxiboy
    Maxiboy
    Hi everyone! Whenever I get a new bike /car. I drive it around until I litterally run out of fuel, obviously I carry some fuel whill doing this. It gives me an idea how accurate the fuel range reading is. Example, my XR5 when it reads 0Kms left I have 3 litres left. ON the Captiva it runs out totally when the reading says 70Kms left. Do the experiment, it will give you some confidence if things get tight.
