Online: Soapbox2627
Turn Signal Wire Rubbing
  • markmckenz
    markmckenz
    I initially thought that my rear turn signal bulb needed replaced but I've since found out the problem is actually the turn signal wires have rubbed against the tire. I've had to tuck them out the way for now.
    The bike has only done 3000kms and is at standard height - Surelly this shouldnt have happened, especially so soon? Question is, will this come under warrenty??
    Also, would they fit the 2013 ones to my bike instead if I asked since they come in black and can do away with the tail light.
    Got to be warranty .
  • IR0N
    IR0N
    it will be warranty if you havent touched anything that 'may' cause this.
  • christoff
    christoff
    Your gonna have a hole to fill up in the rear fender if you ditch the limp dick light. I pulled mine out to give it a coat of basic black and found that was the case. Looks like the wiring wasnt seated properly and came free from the keeper. It's always good to run a spanner , and a set of eyes over a new bike. Is everything still working light wise?
  • markmckenz
    markmckenz
    Def 100% standard at the back.. As you can see from the pic below
    Did you ever check the rear shock spring preload ?
    If you're a big bloke, and the preload is set on minimum, it could cause the tyre to bottom out.
    If you have a good dealer, they may warranty the loom.
  • markmckenz
    markmckenz
    I spoke to HD Perth today.. Will be under warranty! They did say they would fix the wire rather than replace it though.
  • markmckenz
    markmckenz
    I weigh 105kg.. So not exactly heavy, I've only ever riden it 2up once for an hour or so?
    I'm a Harley newbie so I couldnt tell you what setting its on.
  • Chopz
    Chopz
    At 105kg your not exactly tinkerbell mate, no offence
    Riding 2 up for 5 minutes on a soft preload setting would do that sort of damage pictured above, I'd say that's ya problem
  • markmckenz
    markmckenz
     Some pics of the springs,
    You'll see the sires hanging down on the side of the rear fender on the first picture.
