Harley mechanic???
  • bennysportster
    bennysportster
     Any good harley mechanics in sydney?
    Wanna fit my ape hangers and cables, id do it myself but i got no freaking idea.
    Went to harley dealer and got a quote for the job and they told me $800 to do the job.
    I nearly had a heart attack....... far out to buy the bars and the cables cost me less.
    Please hook a brother up.
    Dave at mild and wild in prestons
  • IR0N
    IR0N
    why not have a go yourself? its not that hard... save cash and you will be much more happy knowing you did them! Youtube is great for 'How to' videos check it out.
  • bennysportster
    bennysportster
     if i did i wouldnt ask on the forum,
    Checked on youtube for any vids but no luck as yet.
  • bennysportster
    bennysportster
     just the fitting,
    well i already bought the bars and ordered the burly brand cable kit for my bike.
    so just need someone to hook it all up once the cables are in
  • bennysportster
    bennysportster
     Sorry im not mechanical genious like you!!!!
    I only wanted some advice, not get bagged out! Geez man get a life!
  • bennysportster
    bennysportster
     Thanks Iron.
    Nice to know there are some helpful people out there.
  • 666
    666
     Mate you will be ok do it yourself google and learn there is loads of help here or jump on xl forums us
  • 883n Harley Convert
    883n Harley Convert
    Benny I can give you a hand with the cables, I've had mine apart a few times. There's a few ways to do it, it's a slow process but not as challenging as you think.
  • bennysportster
    bennysportster
     Is it easy for a noob like me to install
    16 inch apes
    idle and throttle cables
    electrical wiring extension
    clutch cable.
    brake line change and brake bleed.
    to me its a daunting task that is all, thats why im hesistant to do it myself.
    i might take you up on that offer harleyconvert, if all else fails.
  • bennysportster
    bennysportster
     Sic! Thankx fellas,
    As soon as these bloody cables i ordered come in i might give it a go.
    Prolly do some research until then.
    Thanks agen. if i need help ill holler for guidance.
