Online: Rextheute2022
Can I fit standard Streebob pipes on a Wide Glide
  • quirky
    quirky
    Hey fellas does anyone know if I can fit standard pipes off a '13 Streetbob on a '12 Wide Glide> Cheers, Quirky.
  • FatRob
    FatRob
     I have used Street Bob pipeson a FatBob, so if the sensors match I don't see why you can't do the same.
    FatRob
  • quirky
    quirky
    Cheers Fatrob. I think I found a set off a Wide Glide so sorted. Your bike looks good mate.
