spotties
  • shfunky
    shfunky
    Anyone out there put a spotlight on their bike and if so did you wire it into your hi-beam cct or put a relay and remote switch in?   Thinking of putting a spotty on as the road out to my place from the highway is roo territory at night.
  • toxic
    toxic
    Had them on my last BMW, put the relay under the seat, use a fused power off the battery & wire up just like a set on a car, I'm sure there would be plenty of factory options out there, picked up the high beam wire at the back of the headlight & yes I believe ya need a switch to be legal.
  • Cyborg
    Cyborg
    I had my fog lights on my Heritage changed so they work on high beam only and also through a toggle switch if I don't want them on.They are putting out 100 watts each and compliments the 100 watt High beam.
  • shfunky
    shfunky
    Thanks for the replies forum members, I should have realised they have to be the same as any vehicle, ie wired through hi-beam, I assume the hi-lo beam switch's on heritages ect  that come standard with spotties are the same as any other Harley with just a headlight?, would hope my switch on my Streetbob can handle the extra current from a spotlight as well as the headlight. Yeah and what's the go with the yanks  when they switch on the high beam the spotlights switch off??
  • Hoodaman
    Hoodaman
    Thats what happens on my RKC......never could work that one out......High beam to me means the works but they switch off....go figure..
  • Hoodaman
    Hoodaman
    Heya DLUX..thanx for the thoughts mate.....yteh i cant work it out either...to me if i switch on the high beams it should be the spotties as well.....dont like this set up but im a techie so ill work it out...
