Online: B0nes, Nino
Can any 1 recommend a good wet/w pants>?
  • careyman
    careyman
     Hi guys, whats a good pair of  wet weather riding pants (to go over jeans etc) I have the old standard bright yellow ones rolled up for a rainy day but would like to upgrade... Any 1 know of pants that have a strap or clips for straps to go under boots to keep the legs down?
    Cheers Cez
  • IR0N
    IR0N
    I have a set of R-Jays and they are great. Slip on over my boots no worries.
    http://www.rjays.com.au/home/products/textile-vector-pants.html
    Motodry works a treat for me. Compact, very excellent waterproofing and cheap to. I think mine were 30-40 bucks.
    Used em in a 5 hour mega downpour on way to Melbourne in December 2010 during floods and totally dry underneath when i took em off.n Got matching top to for about $50.
    Under a hundred for both and best i've used so far for the money. Hope this helps.
  • carwelder
    carwelder
    Only thing I strongly  recommend is to get ones that are easily slipped on over your boots while by the side of the road.
  • Maxiboy
    Maxiboy
    Those Dririder suits are awesome! Had one with my last bike and it was watertight and it didn't matter how much it pissed down you stayed dry. If you like the gear and it doesn't have the elastic straps to go under the boots just sew some on. Takes 5 minutes.
  • Burnzi
    Burnzi
     Yep these ones, grouse.
  • careyman
    careyman
    thx guys I`ll get in a have a butchers hook at em
    Hey Burnzi, looks like you've done modeling at some stage in the past.
  • Burnzi
    Burnzi
    Actually I have but it was a long long time ago when I was a lot more buffed and the local Kindergarten mums were damn hot (Kindy fashion show) I was volunteered by my ex-wifes best friend hehehe
  • Rick1310
    Rick1310
     I just got a set of Harley brand & I was surprised they are quiet good pay a little more but have a few god things on them. Material on the leg so they don't melt on the exhaust & straps under the boots have used the suit 4 times so far & have stay dried. Thats a bonus as well.
  • 06 Softail
    06 Softail
     I have Moto Dry wet weather pants. Fully insulated, plenty of padding in the knees and backside, plus have elastisized material at the bottom of the legs. They are that good, they could be worn if you were skiing or snowboarding or just holidaying in the snow. I purchased mine at a local motorcycle store near my workplace. You can wear these over jeans or shorts too.
  • Burnzi
    Burnzi
    Hey Carey I will find her card and PM ya.
