Online: Soapbox2627
Different axles sizes
  • thommo18
    thommo18
    Is it possible to change the bearings in a 1997 rim that uses a 19mm axle to bearings that will suit 25mm axle ?
  • Crowy
    Crowy
    Yes
    52mm Outside diameter x 1" inside Diameter.
    Fleabay is your friend
    just remember the 3/4 bearings are wider than the 1" inch so you may have to change wheel spacers to suit
  • 883n Harley Convert
    883n Harley Convert
    + 1 I'm going through that issue at the moment, 3/4 bearings are much wider than the 25mm and its causing me all sorts of problems
