Online: Hilly, softfat
cv carby
  • geoff 1408
    geoff 1408
     Just installed a recon cv carb on my bike , this bike has andrews cams in it can you suggest a jet set , i can start with to get it running properly ,
    lots of backfiring at the moment - recon carb is a stock unit i would say.
    what motor?
    well sounds lean did you also use new manifold seals & new seal where carb push's in?
    first check what size pilot you have now let us know & what mj. there is a few different needles too but if its stock needle that bike came with? you can put a small electric washer under the needles head to lift it up & bring the richer curve of needle in earlier. but first need to know what is in it now,
    +1 there...we need more info if yah want help.
  • geoff 1408
    geoff 1408
    Ok Boys, It Is A 1450 With Andrews Cams (dont Know Sizes) Rinehart Racing Pipes, And Will Only Run On 98 Octane, The Carby That Came Off Was A Mikuni, Was Causing Too Much Grief So I De Cided To Go Back To A Cv (harley Recon).
    At The Moment It Has a 45 Pilot And A 180 Main , Airscrew About 2.5 Turns Out.
     drill 46 or buy a 48 idle jet  , 200 main ,  mixture screw 3 turns out
    Larger pilot will stop your deceleration popping. Try a 48 pilot and 190 main and put in a Dynojet kit.
    How much for the old Mikuni? I am looking at fitting one to my blower engine as I keep popping the CV slider rubber...lol
  • marco1982
    marco1982
    ive got cv with stage 1 dynojet kit with 180 jet with the clip on slot 4 but no cams so if i was you i would go the 190  160 is standerd
